42' sonic twin 500 efi's question
Results 1 to 3 of 3
    Dec 2009
    Default 42' sonic twin 500 efi's question
    i have a 42' 2001 sonic twin 500 efi's and bravo drives. one of the drives goes in forward perfect but takes 10-15 seconds to go into reverse, been doing this all season. just drained the drive oil and it looks great... any thoughts ?
    i have not had any issues with the other driver
    thanks
    Senior Member whipped565's Avatar
    Rossmoor
    Quote Originally Posted by jamesscarroll View Post
    thanks
    Check the cable, mine did that last summer.
    JWM
    JWM is offline
    Boat Test GURU JWM's Avatar
    Santa Ana, CA
    As whipped565 mentioned checking the cable with the mercury tool is an easy thing to do.
    Second I have found over the years that sometimes the gear oil gets hot on the top gear set and can create carbon. This carbon can create enough resistance to slow down the movement of the clutch.
    You can take the rear cover off the drive and inspect the clutch assembly.
    You won't see the complete gear set but it will give you an idea
    JW
