Raysoncraft LP
Results 1 to 6 of 6
Raysoncraft LP
    Default Raysoncraft LP
    Hugh James suggested I ask you for advice.Redoing the stringers and floor on this v-drive. It is supposedly from the 60's era. Under the shaft log I found 4 inch fiber bearing encased in a "blob" of white marine-tex surrounding the propshaft. Opinions vary as to whether it is needed. One is that the prop shaft is 68 1/2 inches long does not need to be there. The other is it replaces a whip strut. Really want to "Get her wet" soon. Can you advise best decision.
    "BadBehvior"
    Larry
    Still Trying for Info.
    BadBehavior
    Boat Bling Distributor New Mexico Bullet's Avatar
    Farmington NM
    Its best you call Jim at the shop=714-540-8908. Hell he might even be there
    JWM
    JWM is offline
    Boat Test GURU JWM's Avatar
    Santa Ana, CA
    LARRY: In my opinion the bearing support does not need to be there. I would much rather use a whip strut and delete any leaking issues if any. That system sound like a pour man’s fix for a whip strut.
    Some guys don’t like whip strut's but on most pleasure boat’s I find then to work quite well.
    And guess what I’m in the office today and not testing boats at the lake New Mexico Bullet. LUCKY ME.
    JW
    Farmington NM
    JW[/QUOTE]
    Thats not good you better get out of there and head for some water
