Ignition ??
Results 1 to 7 of 7
Ignition ??
    Senior Member jetboatrich's Avatar
    Sep 2008
    Saint Charles, Illinois, United States
    Default Ignition ??
    Went to take the boat out yesterday, was in the driveway and wanted to make sure all is good. Turn the key and nothing, no guages, etc. I had the batteries on a trickle charge the night before and it started the day before, but my battery was not 100%. I checked my battery with a battery tester and it checks out good.
    I checked voltage at the battery terminal on the ignition switch, 12 volts. When I turn the key power goes away, release the key it starts to come back.
    Has the MERC, 454, 1986
    JWM
    JWM is offline
    Boat Test GURU JWM's Avatar
    Santa Ana, CA
    The first thing I would check is the Battery Amp output. Sounds like your battery does not have any amps. 12 volts but no CCA.
    Also check the main battery cable for corrison. Sometimes you need to peel the plastic cover back just a little and look at the cable condition. Remember to check the ground also.
    JW
    Sep 2008
    I was leaning towards the same thoughts, stereo comes on with 3 different amps, if it can run these, it can make my guauges work, so not the battery. I will mess with the cables from the perko switch to the starter, etc?
    Lake Havasu az.
    Bad connection at battery cables or ground...voltage will pass until you put a load on it....turn the key half a dozen times to make it fail and find the connection that is warmer than the others
    Originally Posted by gn7
    I'll concede, but
    David Olsen of Tamarc Fl. tricked his mother into giving him $27,272.50 and yet refuses to help his 94 year old mother in any way.
    Orlando.FL
    Put a load tester on the battery and as been alluded to check cables for corrosion.
    Sep 2008
    Quote Originally Posted by Schiada 201 View Post
    Thanks for all the responses
    I have a bettery tested, which puts a load on it and it was fine.
    I am traveling this week and will check all the connections this weekend, again
    Sep 2008
    Tore into it yesterday, messed with one at a time and was not making progress pretty much took all connections apart and cleaned them up, all good now.
