454 problem
Results 1 to 3 of 3
454 problem
    Nov 2009
    Default 454 problem
    I have a chv 454 in my carra jet boat,it makes a noise at 2800 rpm to 3000 rpm like you put screwdriver in a fan blade.It will onley do this in the water.The motor runs grate the rest of the time. Need help.
    Sep 2008
    Yuma, Az
    the same thing happened to my 454 and it was a flat cam lobe and a few bent push rods. it would do it above 2500 rpm's and sounded horrible. sounds like its time for a rebuild.
    Ultimate 21' Jet Boat
    Nov 2010
    Default odd noise
    Are you sure its not your fly wheel touching anything ? That has happened to me on past jet boats at certain RPMs
