i have a 30 over 454 bbc full mechanical roller everything 990 heads 13to1 comp i have aquired a 717 lift cam 270intake and 278 ex. @50 108 lsa operating range is 4000 to 6800 it will be installed in a sanger flat 15% gears no trans just gear box. dry ex or banderlog water management i am told that the cam is way to large and would cause engine to have no bottom end torque since i am not using any sort of stall this is my first v-drive and there is nobody that i know who has any info about a good profile for this application any info would be greatly appreaciated this will be a lake burner not a racing boat but i still want it to haul the mail thankyou alan from mi.
LinkBack URL
About LinkBacks
Also I'm not sure what "banderlog" water managment is but I wouldnt be putting any water into the pipes with that cam....unless you like milk shakes in your oil pan!
