rpm question
Results 1 to 2 of 2
rpm question
    May 2011
    Cerritos ca
    Default rpm question
    i recently pulled a twin turbo 468 out of my 21 ft cheyenne, i rebuilt the motor without the turbos. Its now a 11-1 comp solid roller .070 over and it only spins about 4200 rpm at best..to the best of my knowledge it a 29% overdriven c-500 casale..my question is how much rpm should i see at full pull?
    May 2011
    Cerritos ca
    maybe a better question would be if i were going to change the v drive gears and the prop, since mine has signs of obvious wear, what would be a good combo of gears and a new 3 blade prop..
