casale gear change question ?
Page 1 of 4 1234 LastLast
Results 1 to 14 of 50
    Jul 2009
    jackson , michigan
    Default casale gear change question ?
    would going from 22% to 32% make a noticeable difference in a gear change . i would like to put some more gear in my boat . what are some of the gear ratios you guys are running .
    what kind of boat do you have? And how much power is in it...do you know what it weighs? What prop is under it?
    Jul 2009
    jackson , michigan
    flat bottom v-drive 17ft , 550 hp , 11 3/8 - 14 , 1500 lbs give or take a little . i am going to try and weight it . just have not done it yet ..... thanks for your reply ......
    Those gears (32's) seem awful big for your motor. What rpm are you turning with the 22"s ? I have over 700 hp and I run 12"s with a 11 1/4 16 menkens prop and top out around 7100 rpm.
    armandshammer
    Jul 2009
    jackson , michigan
    Quote Originally Posted by Desperado View Post
    motor will spin 6500 rpm ..... i will double check next time i get it out ... it pulls hard ..
    Jul 2009
    jackson , michigan
    Quote Originally Posted by mdsheppie View Post
    bump the prop to a 11 - 16 2 bladw steel prop you got enough gear for the motor or more than you need unless you want it to turn 4500 rpms just my humble opinion your gonna be slower all the way around you are already over geared...and another thing -if for some reason the prop you have is a Brass thing ,shitcan it and buy a good prop ...period ....no doubt thing there 14? good god..No offence intended here johnny just advise,pm me if you need advice we is around
    prop i have is steel .
    Jul 2009
    jackson , michigan
    it just seems like to me the thing is toped out with in 100 yard or less . what kind of speed do you think i am looking a with the gear and prop i have ......
    Jul 2009
    jackson , michigan
    what brand hull? I stand by the bump the prop to a 11x16 tho
    the hull is a 68 passant . i don't know how well known the hull is ...
    Jul 2009
    jackson , michigan
    Well known around here like I said the prop....
    getting a prop is way better them having to buy gears . i would have never known i was over geared .
    Jul 2009
    jackson , michigan
    Johnny still dont see a pic so youre boat might just be a figment of our or my imagination havent seen a Passant in 3 weeks btw....
    i didn't know u wanted to see pic of the boat . i can try and post some if you want . my have to email them to you .
    Jul 2009
    jackson , michigan
    no hurry when you can is your prop you have now a 3 blade bronze one?nevermind I just saw you say its steel where are you located?
    jackson mi , two blade steel ....
  13. #12
    Jul 2009
    jackson , michigan
    If you decide to change gears make sure the big gear is on the top.....
    o.k. i don't have any gears or anything to change around right now . i just need some info to get me going in the right direction .
  14. #13
    Jul 2009
    jackson , michigan
    does anybody know if there is a spot to sell or trade parts on this fourm ?
  15. #14
    Is that how you set up your blower motor...pizza on top...lol
