Well this kind of goes along with don't put a egg in a microwave..
1. don't purge your methanol injection with tri-flo @ 100 psi while smoking
2. never put a un-opened can of Bud on the buffer to make it shiney![]()
You wasted my Bud thats just alcohol abuse right there
Heres one with a blower on the motor dont ferget to remove the ratchet or breaker bar before you start the motor (makes a mess out of your timing chain cover)![]()
-Don't forget to install the pressure gauge in the intake manifold before starting the boat in the water.
-Don't lay the dipstick on the battery
-Don't stick your face over the carb while adjusting the distributer
And I'll bring Shep a metalflaked Bud for the winter party.![]()
Do not use the same kind of beer can that your buddies are drinking out to prime your carbs with gas. They will cry big boy tears when they pull a tug off of it.
don't have your wife launch you off the trailer just to remember the boat keys are in the truck ash tray.....![]()
Don't stand up when somebody bigger than you says shut up !!!
/ The Few The Proud TheBlown
Never tell your Wife, how much you spend on the boat!
