engine and out drive
Results 1 to 7 of 7
    Feb 2010
    Default engine and out drive
    building a boat using alfa 1 outdrives how criticle for left and right outdrive two rights or must it have a left and rt also does one engine need to run bacwards? or is it done in the out drives?
    Member danfornow1's Avatar
    Sep 2009
    Troy, IL
    Quote Originally Posted by materal girl View Post
    Some one a lot smarter than me will chime in but here is what I think is right.
    Left and a right is best for handling, but not mandatory.
    I believe its done in the out drives.
    Senior Member CHEVY JET's Avatar
    NORTH AURORA, IL
    All I can tell you is that a top fuel hydro that has twin shafts has a left and a right rotation prop on it witch is done in the gearbox, so that the boat goes strait. I dont know about io's, but I would say that the outdrive most likley has a right hand, and a left hand rotation. If it where me, id ask the open water gurus with the big boats. Just my two cents.
    to the top or to the shop feline frenzy's Avatar
    Jan 2010
    yale mi.
    both motors spin same direction,clockwise! 1 rh and 1 lf is bestter for handling,and be careful how much horsepower your going to put through an alpha drive or they will self distruct!
    Senior Member The Violater's Avatar
    If you run 2 rights, the rt one will overheat at high rpms, the water will blow away from the pickup in the lower unit on an alpha. Also it will torque steer. You definately need a rt and a left with any kind of power.
    / The Few The Proud TheBlown
    Feb 2010
    Default out drive
    ok i take it both engines spin clock wize and the out drives are what spin left and right. witch on on which side and how do you tell them apart? what size props on 30ft x 8ft with 260 hp engines and what rpm aprox at 30mph
    Jan 2010
    yale mi.
    Default props
    to tell direction on drives spin drive shafts and see what way the prop shafts are turning,right on right side,left on left.go to mercury racing .com and they have a prop slip calculator or just google prop slip and there's alot a good sites,better yet call julie at throttle up propellers in florida,she is a very nice and extremely brilliant prop woman.you need to know your lower unit gear ratios,
