Duramax question - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 20 of 20
Duramax question
  1. #15
    KAP
    KAP is offline
    32 DW X-CAT KAP's Avatar
    Casa de Cappy Diego by the Bay
    Quote Originally Posted by Schi-502 View Post
    I just rotate the key to the run position and then to start. Fires right up!
    But wait!!!
    Does anybody else have a "Heavy Fuel Vapor" smell coming from the engine compartment?
    My dealer says to "live with it!". My truck has been in the shop six times for the same problem. Can't use the otside air supply while driving. Dealer says "Keep it on recycle and you won't smell that smell".
    Don't seem right to me. My first Duramax.
    Comment:
    I have had that diesel smell come into the cab several times. I notice it when I back up or standing in traffic---it just happenned again yesterday.
    It does not seem to be a everyday problem and I can use the outside air no problem. I was thinking the fuel water separator might be leaking as the fuel pressures are really high.
    Thought, you would like to know your not the only one with that issue. It seems to be intermittent---if it gets any worse it will go to the dealer.
    KAP
    Senior Member HPBoats83's Avatar
    Corona, CA
    If you HAVE to run the recycle air full time, and the dealer can't find out where the smell is comming from, I would take it to another dealer or contact a lemon law attorney. One website (another forum) that I have been going to quite a bit is www.dieselplace.com There is alot of very useful info over there on the duramax's.
    James
  4. #17
    Corona, CA
    First post in this thread will have some interesting info on the smell. Take this to your dealer and ask if he has investigated this as one of your possible problems.
    http://www.dieselplace.com/forum/sho...d.php?t=256698
  5. #18
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Thanks
    Thanks for the info. KAP & HPBoats83.
    Great site. Signed up/registered.
    Loose, the Dogs of War!
  6. #19
    Senior Member JakeC.'s Avatar
    palmdale ca.
    Quote Originally Posted by HPBoats83 View Post
    James
    that is a great sight, i am on it as well. same screen name as here. if you have any questions feel free to ask me. i am a d-max tech.
  7. #20
    Default Thanks for the input
    Quote Originally Posted by KAP View Post
    Comment:
    KAP
