Impact or Stress Crack
Results 1 to 8 of 8
    Apr 2012
    Default Impact or Stress Crack
    My question is I noticed these crack on the hull in the pad area. I am quite positive I didn't hit anything manufacture says it is due to impact. There is no signs impact however is it possible you can do this damage without knowing? Boat is 2007 bass boat with 150hp Area where it is cracked is first point of contact with the water on plane
    Thanks Chris
ID:	155734   Click image for larger version.
    Senior Member fourtznme's Avatar
    With no physical damage, I would have to say stress crack. Just my .02
    Murrieta / Needles Marina Park
    Apr 2012
    Thats what I'm thinking, If this is repaired is there a chance of it returning? Stressing me stress cracks......
    I am not an expert, but I am sure that it is like a weld, if done properly it will be stronger than original.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    could be just the gel coat that is cracked, or it could be deeper, best case is its just the gel, worse case to repair it you will have to grind out the cracks and reglass it.
    Apr 2012
    Thanks Folks, I will be sending it in for repair hopefully this will be the last of these cracks...
    B- Bring
    O- Out
    A- Another
    T- Thousand
    West Mich
    Quote Originally Posted by ChrisIliohan View Post
    Thanks Chris
    Chris , i have seen this type of damage more then once ,and if you do not try to repair the area of concern you just might end up with more damage in the long wrong because water can and will wick into the crack depending on how bad it actually is ,and maybe cause delamination down the road , and to the core if any , ect . Chris , just curious do you know anyone else that owns a rig like yours ,and if so...... you just might want to take a look at there boat because sometimes when a boat is being designed, and looks good on paper that is not always the case or should i say poor engineering , and could you maybe post a better pic of the strake . just my 2 cents .
    concord, ca
    Default stress
    It's also the first point of contact with the beach, if you ever beach it. X2 on geting it repaired. Water will seep in there, and the pressure while running could peel that back. Speaking from experiance.
    Jerry
