[Question] Repainting my jet drive
Results 1 to 3 of 3
    Member tator321's Avatar
    Mar 2010
    Cocoa Fl
    Default Repainting my jet drive
    Due to $$$ being in high demand but short supply I decided to strip and repaint it my self verses powder cote! I have read some post of others doing the same and they used appliance paint from home depot or Lowes. I found it small bottles with a brush but not in a spray can Does anyone know if comes in a spray can ?
    thx for any input,
    Dave
    Default advice
    Its cheaper to do it right the first time. Powdercoat isn't that expensive.
    CAPTAIN KRYLON
    Jul 2009
    LEWISVILLE TX
    [QUOTE=tator321;1624207]Due to $$$ being in high demand but short supply I decided to strip and repaint it my self verses powder cote! I have read some post of others doing the same and they used appliance paint from home depot or Lowes. I found it small bottles with a brush but not in a spray can Does anyone know if comes in a spray can ?
    thx for any input,
    I got appliance epoxy from Lowes in a spray can. The only warning I would offer is use multiple light coats. If you put it on thick and wet it will not dry.
    On the second try:
    I stripped mine with aircraft stripper, sanded with 100 grit. Painted it with the epoxy. Let it dry for a week. Wet sanded with 320 painted it again.
    It looks as good as a factory pump.
    No it is not looking like a autorama powdercoating job.
    But anyone that would powdercoat your pump for the $30 I have in supplies on this deal is not someone you want doing it anyway.
    The best thing about using the epoxy is you can wetsand and touch up a scratch.
