I was wondering, when I put all the hardware on the boat, fins, rudder, water pickup tubes, I used silicone , And when I applied it, I just put it on the part. , then I bolted it down , all the silicone squeezed out and I wiped the excess off. I was told that the correct way to do this was to not tighten it down all the way, and let it set up over night, then go back and tighten down all the way this creates a gasket . I did not do this , the last time we put all the stuff on the boat they didn't even use silicone, they used some two part epoxy stuff that you would mix together, it dried hard as he'll and didn't flex like silicone. The question is will it be ok how I did it, I never let it set up I just tightened it down , I really don't want it all to leak, I could pull it all off and do it again , but I think it would be ok but wanted to know if anyone has had any experience with this,![]()
LinkBack URL
About LinkBacks
