wet sand and buff..
Results 1 to 1 of 1
wet sand and buff..
    Senior Member hpltree's Avatar
    Sep 2011
    ventura , ca
    Default wet sand and buff..
    you guys that have done it ,, super job and thanks for the advice.. and all that are thinking about it run down to the store and buy some 1200 and 1500 grit 3m wet and dry sand paper along with a meguires 3 step polishing kit... i hit it with the 1200 then the 1500 then the cutting compound with a polisher from harbor frieght, then the polishing compound by hand followed by the wax by hand and she looks great..... the little pic on the bottom was before
Name:	test float 005.jpg
ID:	166634   Click image for larger version.
Name:	test float 006.jpg
