Best Materials to repair my boat??
Page 1 of 2 12 LastLast
Results 1 to 14 of 15
    Jun 2012
    Default Best Materials to repair my boat??
    Well I am in the middle of project baja which I just bought a month ago. I am rebuilding the jet drive and painting it...The list goes on....but the price was right so fixing it up isn't a big deal. Well last night I discovered she is going to need some repair on the hull. I can't believe I never noticed this til now (unless this is the result of going over a log on the river on my last outing, or if it wasn't that bad n the log finished her off). But the boat always seemed to turn better in one direction than the other before I hit anything so I suspect there was some prior damage I missed. If u look from the right side of the boat u can't see it but on the left u can if u get all the way under the boat. It doesn't take on any water at all from the damage because the gouging/cracks aren't that deep. I'll post some pics up but I was wondering what resin and all I should use to fix this. I am not new to painting or body work.....but I am new to boats and fixing fiberglass on a boat. So let me know whats some of the best affordable products I should round up to get this fixed and ready for me to paint. Do I just epoxy resin/fiberglass it, sand it, use some glaze over it, prime it and paint it with the rest of the boat?
    Jun 2012
    any advice on where to start and what to use? It looks like the long scratch down the length is just the gelcoat thats gone. but I will inspect it better tonight since I have time to work on it. It is a closed bow boat so the option of cutting all the damaged parts out and fixing from the inside really isn't an option. Here's what steps and products I think I should use.
    Get the broken stuff out, grind/sand the bad areas and clean with acetone then use Epoxy resin with fiberglass mat to make the repairs under there then use some wax paper taped to the boat over it while it cures. sand it to the contour of the boat, gel coat it and then paint over the gel coat when I paint the rest of the boat.
    Sound like I have the right process for fixing this properly? or am I missing something
    West Mich
    Hey guy , that sounds easy enough but .........................gel and epoxy are not very compatible unless used with with Duratec ( primer ) Express Composites' line of Duratec Products which now can be purchased by the Quart for $ 25.00 ,and comes in white , black or grey . (white- 714-002)
    Jun 2012
    that's why I asked the experts . Usually when it seems too easy then you're overlooking something hahaha. any other suggestions or things I'm missing? or does it sound like I'm on the right path? I am using an imron style paint..will I even have to gel coat it or will it stick to the epoxy resin and that be suitable?
    West Mich
    Quote Originally Posted by 84lsvette View Post
    I guess for starters seeing that you are going to use epoxy for this repair what type of fabric are you going to use , and seeing that you are going to be spraying a paint similar to Imron you definitely will need a primer , and yes .................skip the gel altogether.
    Jun 2012
    I got a change to look closer at it the other day. Where it is cracked until halfway back the outer layer is delaminated so basically most of the flat part of the bottom needs to be redone. How it looks like it was constructed is the only part that is broke is composed of fiberglass mat. Which is where the impact broke it and cracked it to the back which separated from the next level which is made from cloth. So since the mat is the part that broke is a layer of mat I plan on using mat to build that layer back up. Thanks a lot offshore ginger you are helping me a lot!
    West Mich
    Chopped Strand Mat's / CSM , Not Recommended To Be Used With Epoxy .
    Jun 2012
    I took it to a shop that is run by my friends boss and he said it is totalled and not worth fixing so it looks like I need to find a new hull for my engine/pump
    Senior Member rebel30's Avatar
    Oct 2011
    Twin falls
    It's not totaled . It can be fixed . There's enuff people and info around here you could buy some resin and cloth and build a boat from scratch. I'm guessing ur friend is swamped and is trying to turn away work . Do it ur self and save some mOney . Or throw it away and buy onother one that probly needs work done to it as well .
    Jun 2012
    could be. the weird thing is it never took on any water and it was sitting/driving on the water for awhile after it had the run in. What do you think the best approach. would be. grind away the bad stuff and see how bad underneath it is, if it isn't cracked all the way through repair from the bottom, or since the floor could use re-done anyhow should I cut it out, use some wax paper/cardboard and work from the top side of the boat?
    Aug 2010
    grind/sand down until it solid, feather it out, build it back up from both sides. done deal.
    it wont be too expensive, but it'll take a LOT of hours and manual labor and dust.
    while you're at it, sand down the whole hull and have it painted or gelcoated. in the end you'll have a whole new boat. its your call if you want to go thru the hassle or just get another hull. one way you'll know exactly how your boat stands, condition, etc. the other will just be another hull that could do the same thing... its up to you how much do you love your boat?
  13. #12
    Jun 2012
    I have no problem putting the hours and labor in. I got under there and looked better and under the splintered mat and the cloth underneath is not cracked or broke at all... (probably why it didn't take on water). Looks like just 2 thin layers of mat with gel coat thats messed up. So I am going to pull the engine and drain the fuel and flip it over and repair it which will also make it easier for me to sand and paint the bottom side. I repaired a surfjet for my friend over the last few days and using the fiberglass and resin is easy to make nice strong repairs. It is turning out great. But for the boat should I use cloth and epoxy resin? or mat with polyester or whatever resin you are suppose to use with mat. I will probably order my resin from us composites. I have a bunch of mat and cloth already. From what I've read epoxy is stronger and a little more flexible so should I order epoxy resin and use cloth to repair the broken mat on the boat.
  14. #13
    West Mich
    84, first off just remember that if you make a mistake doing this repair it can be fixed considering it is only a dumb piece of fiberglass which means you are smarter then it , and yes we can & will talk you thru this whole project from the materials to each and every step that needs to be done , etc , etc . # 84 , i explain this often and the type of resin you decide to use depends on your wallet right down to the fabric , and if by chance you decide to go with www.uscomposites.com using there 635 you will not be disappointed because it offers a longer pot life which means more work tome with less waste , and no stank .
  15. #14
    Jun 2012
    Thanks a ton guys! I appreciate the help very much. I would like to fix it on a budget..... but obviously not sacrifice quality. I know you have recommended that 635 resin to a lot of people. Which cloth would work best with it for the repair. If you need more info just ask and I will get it for you. It will be nice to get this thing fixed. I like taking old things and restoring them... And I hate to see things go to waste!!! plus its a fun project. New paint will bring this thing to life!
