gel coat question
Results 1 to 2 of 2
gel coat question
    self proclaimed idiot Adam_R's Avatar
    Dec 2011
    Corona Ca.
    Default gel coat question
    I have done gel in the past and was told to spray PVA on the finish coat. What does this do? Is a wax additive better?
    Quote Originally Posted by Adam_R View Post
    You have to seal the gel coat, for it to cure properly. Wax additive in the gel works, but I prefer spraying PVA over the final coat. Wax can mess with your color match, if you are doing a blend. Scotty Pierce
