[Question] Open bow mod? Doable?
    Sep 2012
    Default Open bow mod? Doable?
    Considering an open bow mod to this boat...
    Thoughts? Advice? Yes paint /interior are already budgeted... New 455 already placed...
    Oct 2010
    661 So. Cal.
    Short answer.... Yes you can do it. Are you familiar with doing glass work? That project is not for the novice. You will need to cut your hole in the bow, then build a frame work to support what is left. My advice is to make the boat a mid cabin and not a walk through. Keep the strength of the "bubble" ahead of the dash.
    Sent from that vibrating thing In your pocket using Tapatalk
    Sep 2012
    Quote Originally Posted by SuperJet View Post
    I like that advice... Meeting with my glass guy tonight!
    Oct 2010
    661 So. Cal.
    Quote Originally Posted by Tkennady View Post
    Very cool... Be sure to start a build thread on the conversion.
