need help
Page 1 of 2 12 LastLast
Results 1 to 14 of 26
need help
    Senior Member eddiedowey's Avatar
    Sep 2009
    lake greenwood sc
    Default need help
    I'm trying to redo the floors in my hydro
    I'm not sure what glass to use. I read other post
    and from what I gather #1708 and finish cloth is
    what I need to use any help would be appreciated
    thanks
    eddieClick image for larger version.
    West Mich
    Just curious have you given much thought on what type of resin you want to use Poly , Vinyl , or epoxy because your choice of resin depends on what fabric to use .
    Sep 2009
    lake greenwood sc
    Default help
    I was hoping you would respond. I really value your opinions
    I dont have a clue what to use at this point. I have done a little glass work
    on cars back in the day. I thought this would be a easy fix over the winter
    so any direction from you would really help
    thanks
    eddie
    West Mich
    This is just a suggestion but i would go with Epoxy considering it will have a longer pot life , which means more work time , with less waste ,and no stank , which is a god send in itself . Eddie , i have to say that using Epoxy will cost a little more in the long run put well worth the X-tra money spent and might i recommend going with # 635 which is sold by us composites or www.uscomposites.com which can and offers the best bang for your buck. ( price )
    Sep 2009
    lake greenwood sc
    Default help
    can you use epoxy over fiberglass
    I wasn't planning on removing all the glass off the stringers
    West Mich
    Yes you can but you must take note that when you start using Epoxy you can never go back to Vinyl or Poly ( Ester's ) because they are not compatiable with each other ( Epoxy) , in short Epoxy will adhere to Poly, or Vinyl , just not the other way around .
    Tabs Up Drives Out J-Bonz's Avatar
    Bay Village, OH & Johnson Creek, WI
    Quote Originally Posted by OFFSHORE GINGER View Post
    Offshore you forgot to add that you want to stay away from using fiberglass with mat if you go the epoxy route... (So dont use 1708, use 1700 biax).
    Tabs up, Drives out................
    West Mich
    Quote Originally Posted by J-Bonz View Post
    Ha Ha Ha Ha , No i did not forget to add that he should stay away from any fabric like #1708 with CSM ( Chop Strand Mat) When using Epoxy~ you just beat me to the draw , and to tell you the truth i was going to wait to tell him depending on what resin he decided he was going to use .
    West Mich
    Eddie , in your pics of the flooring the ply looks a little blackish in a few areas , and is there any delamination or soft spots in the ply ?
    Sep 2009
    lake greenwood sc
    Default help
    I'm not sure
    It is at a friends that is helping me with it
    he has been sanding on it and I haven't seen it in person yet
    I'm going down there today and see what it looks like. he told me last
    night that one of the stringers was a little loose at the transom.
    I will update you on what I find out
    thanks
    I had to sneak in their and try to get one up on ya.... In all honestly, when starting my project that was one that took some time to understand.... As always, great advice you have given. I agree a 100% with it...
    Sep 2009
    lake greenwood sc
    Default help
    well I finally went over to my friends to see what the floor looked like with the glass off of it
    not to good got some wet spots in the floor & one stinger I checked was delaminated in the back by
    the transom. I guess the next step is to get busy getting things toogether.
    Sep 2009
    lake greenwood sc
    Default help
    the stringers in my boat are attached to the floor. when L put new stringers back in it should I
    put them back the same way or should I put them in first and then put the floor in last???
    West Mich
    Eddie , not to sound rude but i would hope you would try to put the stringers in first considering you will need all the space you can get to laminate the stringers to the hull and then proceed with the floor after everything is done or should i say everything that needs to be repaired after the floor is removed , and yes i would put the floor in last . Just a suggestion !
