Filler UNDER Gelcoat?
Results 1 to 7 of 7
    Silverdale, Washington
    Default Filler UNDER Gelcoat?
    Im gonna fly my rookie flag here and ask what kind, if any, filler can be used under gelcoat? I was thinking about a skim coat on my transom that I would block out to fill any slight imperfections prior to shooting the gel. Is it possible?
    I was thinling of some Rage Gold I have but am not sold on it.
    Thanks for the help.......
    Oct 2010
    661 So. Cal.
    Don't waste your money on Rage Gold.. any body filler will do. I use 3m hi build filler, it is half the price of Rage and in my oppinion is better than rage. It spreads easier and sands easier.
    Las Vegas, Nv
    John, as long as the filler is polyester based, it should be ok.
    If you are still concerned you could always mix a filler from resin and microbaloons. I use this all the time for filling and fairing and it sands pretty easy.
    Dec 2012
    The 3M Marine Premium Filler; gelcoat will adhere to it and is is sandable and can be uses above or below the waterline.
    Thanks very much guys. I'll give it a shot...............john
    West Mich
    John , if memory serves me right , i thought you used Epoxy when doing the repairs on the tramson ( correct ? ) and if so.............. you are going to need a filler that is compatible like ( Ad tec's ) P-77 because in the past i have seen the 3-M filler fail when used on Epoxy unless you have preped the surface in primer already with a primer like Duratec .
    Great info Artie. Thanks very much
