advice for stringer and crack repair
Results 1 to 7 of 7
    RBC
    RBC is offline
    Senior Member RBC's Avatar
    Mar 2010
    CA
    Im just trying to get advice and make sure the plan I have is good to go before I order my materials.
    I will be using Epoxy resin, is two layers of 17oz biaxial on the stringers with a layer of 6oz "S" glass on top good enough?
    Also..
    can I just use the 17oz biaxial or do I need to alternate layers of different glass when fixing cracks and filling gauge holes?
    Thanks in advance for any tips or advice.
    sacramento
    Quote Originally Posted by RBC View Post
    Also..
    where is your crack/s ? check out my thread (turbo wogs project) in jet boats. i might have enough info for you. i did wrap one stringer in good shape with 2 layers of nitex.(matt on bottom & weave on top) & called it good . but i did have a crack & ground it out realy good from the bottom & did alot of glassing. pm me if i don't get back here . i am definaltely not a pro but you can see what i did. holes i ground out really wide & all the way to the wood & drilled out larger till wood was clean ,not rotted ,then elmers exterior glued. cut wood dowels a little long ( buy all sizes, make it tight going in) grind dowels flush then glass, over layer then sand down. reglass if not flush. when all holes are done ,wrap the stringer 2 coats of nitex. that is what i was told to do & i did. as for the crack ? where ?pics ? don't bother doing it if your not gonna go ape sh*t on the cracks & get in there deep. my hull was cracked when i bought it & i paid two times for the repair & re-cracked. then a friend helped me.......cracked again. then i ripped the f''er to the wood from the bottom . still holding together & hit some rough stuff so far. 1 gallon doesn't go far on a big project. i kept running out . i finally bought 5 gallons of vinyl ester from "composite one" for low $100's .composite one was recomended to me from outlaw boats,so was the vinyl ester
    RBC
    RBC is offline
    Mar 2010
    CA
    Sorry I should have been a little more specific I will be replacing the stringers. I have already cut them out and was just wondering if 2 layers of 17oz biaxial with a layer of 6oz S glass is good enough when putting the new ones in.
    And the crack is in the corner of the transom I have ground it out almost all the way through and I will be fixing the inside then doing the same thing for the outside. I am just wondering if I can layer the 17oz biaxial to build it back up or if I have to alternate it with another type of glass.
    West Mich
    RBC , the 1700 bi ax will work well , and will fill all the needs in any phase of your project and two layers of 17 oz , and one layer of 6 oz finish fabric will be more then enough material although i normally go with three layers of 17 oz & 1 layer of 6 oz ( for stringers) which on my end may be a little overkill ( beef ) which is something i have done for years and a very old habit that is hard to break but non the less you will be just fine and if i was you i would make ply plugs to fill in the old gauge holes filling in the perimeter of the plug with a thickened putty made from cabosil & resin ( peanut consistency ) grinding a bevel on the edges or perimeter of the plug & hole itself glassing in both sides .
    West Mich
    RBC ,just a quick mention , and that is i think you will find using the 6 oz S glass , finish fabric , chesse cloth , surfboard fabric , will leave a very nice smooth , and clean looking layup that is very pleasing to the eye .
    RBC
    RBC is offline
    Mar 2010
    CA
    Thank you very much for your advice, I am glad to hear that it will leave a nice finish since that is what I am after.
    West Mich
    RBC, well lets see some pics of the project !!!!!
