Type of Paint?
Page 1 of 3 123 LastLast
Results 1 to 14 of 31
Type of Paint?
    Dec 2012
    Default Type of Paint?
    Need help with type of paint for a 72 Kona sanded most of gel coat off ready for paint?
    Replaced all of the wood, can I just paint or do I need to re gel coat first? Rog.
    Senior Member inthecurl's Avatar
    Feb 2009
    So.Or
    Personally I would Epoxy prime entire boat ( that you want painted ). The epoxy will act as a sealer for the new paint to adhere to and no issues of any old paint coming thru, etc.. I would then put a primer on the epoxy and sand to 600 grit, then use a good base/ clear urethane if your doing any metallics or any art work, etc.... If just a standard base color you could get away with a single stage paint and only sad primer to 400.
    No need to re- gel. The epoxy primer will act as a great foundation for any paint system you choose.
    good luck.
    Senior Member johnf's Avatar
    Oct 2012
    [QUOTE=inthecurl;1792434]Personally I would Epoxy prime entire boat ( that you want painted )..( I would then put a primer on the epoxy and sand to 600 grit.)
    Please advise, Prime boat, Then prime the primer?? Maybe I'm reading this wrong? I was going to use Durotech 714-002 white then paint am I skipping a step? Thanks johnf.
    West Mich
    [QUOTE=johnf;1792746]
    Quote Originally Posted by inthecurl View Post
    John , let's take a step back the Duratec white 714-002 is a high build primer and has been used in the industry for many years on boat's built using Epoxy or repairs using Epoxy , Poly , or Vinyl ,and if you want to take into consideration what was just posted above ........so be it , and if you are going to use the Duratec Primer like mentioned in your last post ............you have no concerns at all ~ because the primer you are thinking of using ( duratec ) most likely will offer the most bang for the buck , and if i was you....... i really would re- consider , prepping everything in # 600 grit for paint ~ which is only a suggestion , considering i normally go with something that is more abrasive .
    Silverdale, Washington
    Let me jump in here and offer what little I know.
    The first primer that inthecurl mentioned is used as a sealer. For example, PPG's DPLF 50 which is an epoxy primer can be a great sealer if you add some reducer (per the instructions). This will, as inthecurl mentioned, seal off the boat and what paint may still be there.
    Then you can add a primer surfacer or fillers on top of that. A primer surfacer goes on very thick and sands easily so you can block it out really nicely and get the hull real smooth.
    Reading Arties post, it sounds like Duratech would eliminate the need for the sealer and it's a primer surfacer. I've personally never seen nor used it so I'll defer to Artie on what he thinks of it and how it's applied.
    Good luck............john
    [QUOTE=OFFSHORE GINGER;1793514]
    Quote Originally Posted by johnf View Post
    Artie, is this Duratec 714-002 something that can be applied over a repair done in epoxy AND can be topcoated with Gelcoat?
    Oct 2012
    [QUOTE=jrork;1795850]
    Quote Originally Posted by OFFSHORE GINGER View Post
    Thank you, jrork. Ok put a (sealer primer) Then a (surfacer primer) Then paint. Now I understand what he was saying! I spoke with Jim at Express And he said once the 714 is put on and prepped it is ready for Gelcoat or paint. He knows about Gel-flowcoat but couldn't advise on what paint. thanks johnf.
    West Mich
    John , the Duratec is a primer that i used at Skater for all Epoxy built boat's custom or otherwise , and yes one of the main reasons we started using this primer is because you can spray it on epoxy , sand /prep and then spray Gel (or your topcoat ) without all the X-tra work involved which once again is also a high build primer ( which can be sprayed up to 50 mill's wet on wet ) that costs less then just about any other primers on the market Express Composites' line of Duratec Products which also comes in Black , Grey , or white , 714-002 and might i mention that if you check out there site the price of the primer has just gone up for the first time in two year's ( $72.41 a gallon ) who still offers the best price that you will find anywhere for this product . Just a quick mention ...............when using Duratec there is no need for a special Catalyst / Activator , or reducer , other then Acetone ,and ( MEK) or Catalyst . which is sprayed ,and the bigger the tip the better . John , by the way Hawkeye Industries / Duratec is located in Tacoma Wa .
    West Mich
    [QUOTE=johnf;1796466]
    John , what paint would you like to spray , Imron, Awl Grip, Base Coat / Clear Coat or .............................because i have never had any problems with any brand or make of paint when using Duratec .
    Thanks Artie. I'll check that stuff out. I'm gonna give gelcoat a try. Never attempted it before.
    West Mich
    John ,here is a link to there home page which offers a very good tec / information section on all there products . http:Hawkeye Industries and seeing that you are going to try your hand at Gel go to this link Surface Coatings for High Performance Composites. | Revchem Composites | Composite Solutions... Delivered Daily. scroll down and download there 2013 durakote color guide just for shits and giggles .
    DEG
    DEG is offline
    Senior Member DEG's Avatar
    Mar 2012
    House of kolor
    Kolored primer kd 3000 it's a highbred primer that doesn't have the problems of epoxy and polyester. And it's sand able.
    It's 3 in one high build med build or sealer. Then go straight to base..
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    [QUOTE=OFFSHORE GINGER;1796970]
    Express composites is 15 miles where I live and been using them for all most 20 years. I'm using the Duratec primer now on my project and it is some awesome stuff hands down. It sands like duraglass or a little harder but not much. But most important to me is that it does not clog the paper. You can't go wrong with what Ginger said. He has a lot of good info on hear so keep up the awesome work. Troy
    West Mich
    [QUOTE=APOLLO;1804762]
    APOLLO , thank you for the kind words i also like using Duratec or Hawkeye products , and to tell you the truth just about every Boat Co that i have worked at in the last 25 plus years has used Hawkey products. ( Duratec)
