Help with clear coating a 76 wriest jet!
Results 1 to 5 of 5
    Apr 2009
    Default Help with clear coating a 76 wriest jet!
    Hey everyone, I'm in the process of re-clearcoating my 1976 wriedt jet. My dad and i did it about 15 years ago, but its that time again, and i just wanted to make sure i did everything correct. the clear will be put down over metal flake:
    1) What grit sandpaper should i use to prep for the new clear coat? wet/dry?
    2) What should i use to clean the surface after sanding?
    3) What is the best brand of clear coat to use for this application? How much do i need?
    4) How many coats should i put on? sand in-between, if so what grit? and how long should i wait between coats to apply the following coats?
    Thanks for whatever help you guys can provide!
    Senior Member inthecurl's Avatar
    Feb 2009
    So.Or
    Here is my advise, but take with a grain of salt.
    If your just sanding older clear and re-clearing I would wet sand ( with some Dawn dish soap added ) 800-1000 grit.
    For cleaning/prep go to a local jobber and get some wax and grease remover and go over boat twice with nice clean rags/paper towels, then tack cloth over entire boat.
    Best brand of clear really depends on your budget. After the cheapo clears you really get what you pay for after the $200/ gal. mark in my opinion. A small 17-18 ft. boat with 2-3 coats of clear will be about a gallon of clear ( add a couple quarts if your doing bottom of boat as well ).
    How many coats depends on $$$ for clear, but three coats should be a good start.. You can re wet sand with 1000 grit and add 2-3 more coats, then cut ( with 1500 then 2000-2500 ) and buff if you want a really nice look...
    Others have different opinions so take my advise as just my opinion.....
    Apr 2009
    Inthecurl, thanks a lot for the advice. That seems pretty similar to what I've read......I'll post some pics when she's done
    Feb 2009
    So.Or
    No, ya gotta post before and after pics!!!
    Apr 2009
    Haha for sure
