Removing cover rash from gelcoat
Results 1 to 8 of 8
    Apr 2013
    Default Removing cover rash from gelcoat
    Recently bought a 94 Ultra and just had it shipped cross country, long story short they shipped it with a sunbrella cover on it and the boat now has blue / brown cover rubbing rash all over half of the boat. Before I just into wet sanding a buffing, any suggestions to try ? I put some Acetone on a rag and tried rubbing but and didn't really touch every tough it. The rash looks in the gel.
    New Jersey
    You could try using Mr Clean's Magic Eraser, it works miracles in certain situations. If that doesn't work next you could try a light compound.
    Doug
    280 Profile Cat W/575sci JRider's Avatar
    Lansing MI / Deerwood MN
    Star bright black streak remover or try McGuires cleaner wax. Try wheeling with fine compound if all else fails. I would have thought acetone would have did it...be careful with it as ulit can eat your gel
    21' Bahner Sport ATKpilot's Avatar
    CA
    Quote Originally Posted by Real McCoy View Post
    Doug
    not to jack the thread, but I just found out the other day how great the Magic Eraser works! I had a small dark spot on my white gel and my wife jokingly said why don't you use one of my Magic Erasers on it it. I thought to myself, I not touching my boat with that thing, but later I snuck into the kitchen and swiped one and tried it. I was floored how good it work. I was getting ready to wax the boat so I washed it and then tried the eraser in an inconspicuous spot on the dark blue gel and it came out smooth as a babies azz. I guess I need to tell her how good it worked
    Like JRider said, real careful with that Acetone
    West Mich
    Quote Originally Posted by ATKpilot View Post
    Bull shit ..................because gel coat is resin with a Pigment .
    CA
    Quote Originally Posted by OFFSHORE GINGER View Post
    There, I fixed it
    Be real careless with that Acetone
    So you are saying that acetone is safe with gel? The same acetone that cleans poly resin off my tools?
    West Mich
    Quote Originally Posted by JRider View Post
    Jeb , Acetone is a cleaning solvent that has been used in the industry for many years which is great for not only cleaning tool's but used for wipeing down small and large parts , decks , hulls , molds , and often used as a thinning agent for spraying certain primers ( Duratec) , and sometimes Gel when mixed with Wax Addtive , and not to mention that i have used it on your boat to clean off any dirt / road grime , overspray , etc before and after the boat left the shop . Jeb , you need to remember that Gel is a resin with a pigment that eventually transform's into a solid that is very durable after all is said and done.
