Repair for tank strap bolts that have seperated from floor?
    Jul 2013
    Sacramento, Ca
    Default Repair for tank strap bolts that have seperated from floor?
    Just bought my first flatbottom, a 1967 Sanger V-drive. In the process of cleaning it up I removed both tanks and found that some of the bolts that secure the tank straps that were resined over in the floor have seperated from this area and remained attached to the straps. The bolts weren't glassed over, just had resin applied to hold them in place. I'm considering reattaching them in the same way, but adding a large fender washer next to the bolt head and using fabric to cover both the washer and bolt before applying the resin to hold them in place. Also, the resin has seperated from the wood in about an 8 inch round area near one of the bolts and has caused the wood underneath it to turn black. Do I need to grind off all of the this to expose all of the affected wood? Do I need to grind the affected area of wood as well? Is there a way to treat the wood prior to applying the resin? Any feedback or alternative suggestions for repairs would be greatly appreciated? Thanks in advance. Will be adding pics a little later.
    Jul 2013
    Sacramento, Ca
    Default Pics of tank strap bolts
    Quote Originally Posted by AlterEgo View Post
    Here are the pics
ID:	335177   Click image for larger version.
ID:	335185   Click image for larger version.
ID:	335193   Click image for larger version.
ID:	335201   Click image for larger version.
    West Mich
    Personally , after viewing your first round of pics you have more to worry about then just the tanks considering you have a lot of areas that need to be addressed ( blackish - ed ) wood which usally means rot !
    Jul 2013
    Sacramento, Ca
    I was kinda afraid that was the case. After reading your reply I took a probe to the area and discovered how rotted the wood was. Thankfully, it doesn't appear to have reached the stringers and also appears that it can be repaired/salvaged. Would anyone know or has a resource to find out if their is a void between the floor and the hull on a 1967 Sanger Flatbottom?
