76 Hondo T-deck needs help
Results 1 to 3 of 3
    Member 00 CP's Avatar
    May 2013
    Fallbrook, CA
    Default 76 Hondo T-deck needs help
    My old Hondo, now my sons, has severe gel cracks and also just worn down at the water line. It is a very light hull that flexes a lot (definitely no stepping on the deck). Being this light and thin, I'm wondering what the process would be to repair the cracks. It seems like grinding it out would be the way to go but there doesn't seem to be much below the gel coat.
    Any thoughts/suggestions? Also, any recommendations for a good shop in the Temecula area?
ID:	354834   Click image for larger version.
ID:	354842   Click image for larger version.
ID:	354850   Click image for larger version.
ID:	354858   Click image for larger version.
    Senior Member schiada flatty's Avatar
    Lloydminster Canada
    I think you'll have too sand closer to the substrate till the crack is gone.
    At $100/ hp plus injection oil it's just to expensive to go that slow!
    Sep 2008
    Hollister
    I have a 74 Hondo jet with the same cracks on the deck, I sanded mine all the way down to Fiberglass. Shot primer and painted looked beautiful but all came back with in a couple of years. I think the only way to fix them would to lay a new layer of glass across the deck.
