Gel coat problems, need assistance
Page 1 of 2 12 LastLast
Results 1 to 14 of 15
    Jun 2013
    Default Gel coat problems, need assistance
    I have a 77 spectra 20 jet. Great family cruiser. The top of the boat from rub rail is getting the long wide cracks. Alligatoring on deck. . My delema is how to fix this. Do I send for blasting to remove gel? Have a new deck built from a mold. Or shit can the hull and re rig another.
    West Mich
    Pics would really help .
    Jun 2013
    Offshore I'm glad you replied. I know you will know. I'm taking the photos today and post
    Senior Member Sanger-Spectra's Avatar
    May 2010
    Quote Originally Posted by Nomofun View Post
    To repair these, you will need to get down to glass, any surface repairs will just come back. here are a couple picks of the process i did with my Spectra.
ID:	379929   Click image for larger version.
ID:	379937   Click image for larger version.
ID:	379945   Click image for larger version.
    RPB
    RPB is offline
    Senior Member RPB's Avatar
    Jan 2013
    Gelcoat/resin crack propagation can be caused by many things, the worst of which would be the fact that the resin matrix has reached its use life or has been degraded by some means. The best scenario would be the gelcoat is the only part of the system that has failed. Its not always fixable, yet some do and believe its safe. It will be important to see the condition of the matrix system under the gel and go from that point. You should also plan on looking at other portions of the boat, unless presuming that this issue is just UV/age related is acceptable.
    Like Offshore said post up them pics
    51% of Democrats dont know the earth revolves around the sun and 49% think that Astrology is scientific. (National Science Foundation and National Opinion Research Center (NORC) at the University of Chicago 2014).
    CF BLACK
    : Carbon Fiber Fabrics and Derivatives at the Best Prices
    Jun 2013
    Here is pics. Again it's all over
ID:	380065   Click image for larger version.
ID:	380073   Click image for larger version.
    RPB
    RPB is offline
    Jan 2013
    Top pic....zoom out what part of deck is this?
    CF BLACK
    Jun 2013
    this is why I asked cause i have heard that spectra made a change in resin and gel back then and had tons of issues till they realized it and went back to older system. i also look at cost. a new deck in gel is ? vs repr. a new hull is ? vs painting and fixing this one. . the hull seems good. this is a 1/4 stringer hull.
    RPB
    RPB is offline
    Jan 2013
    Go ahead and peel one of those chips off and lets see whats under it.
    CF BLACK
    West Mich
    Quote Originally Posted by RPB View Post
    I agree , and over the years ........i have seen way to many older boats facing problems with cracks because the gel was sprayed on way to thick because something as simple as a Mil gauge was not used during the initial application of the Gel in the mold .
    Re-member
    Feb 2009
    bay area ca.
    Quote Originally Posted by Sanger-Spectra View Post
    could you please explain the process that you used to do this and how did it turn out ? im under the impression that you grind down to glass then lay a layer of glass over the old glass but then how do you cover the new glass to hide the glasswork and what about the edges don't they want to peel up after some time ?
    May 2010
    Quote Originally Posted by smokinjoe View Post
    Hey Joe, we used 36 grit 9" disks on a low speed buffer / grinder, took the surface down into glass and laid up two layers of 1oz matt and 1 layer of cloth. The edges are freyed and laid over the cap. This was a project I wanted to lean how to do so I took some extra steps to learn and do a few things. I was getting rid of all the original mounting holes, gas fills, vents ect so I wanted a virgin surface. I actually capped the boat before we did the top deck, so it was in essence capped twice. The key is the grinding enough material away to be able to lay down new material and not have a ridge. Once the glass is down you finish with a couple resin coats and finally a wax coat so you can sand and shape. Again this is were your grinding prep comes in because you don't want to be blocking glass, just the final resin coats to shape. We gel coated the entie boat once we were done as well and used that for a primer, I had 95% of all the gel coat sanded off this thing top and bottom as well, boat wasn't a basket case but close to it and I had a desire to learn how to do glass work.
    Here are a few pics of the finished product after initially blocked (don't laugh at my guide coat, it was really late and i think i was a little loopy), painted and then with color.
    There are many ways to do this, and a lot of different materials as well, this is old school and I am sure others will comment on using some more modern materials.
ID:	383745   Click image for larger version.
ID:	383761   Click image for larger version.
ID:	383769   Click image for larger version.
    Re-member
    Feb 2009
    bay area ca.
    I like it looks good !
    280 Profile Cat W/575sci JRider's Avatar
    Lansing MI / Deerwood MN
    Nothing wrong with poly and standard glass. I prefer VE resin and fillers and they are compatible with poly. Once epoxy is used it can complicate future repairs. Ask me how I know this!
