crack in hull question
Results 1 to 6 of 6
    Jun 2013
    Default crack in hull question
    I found a three foot hair line crack on the hull of my sanger super jet in about the middle of the boat right along a chime...... the boat needed a new floor when i got this thing... i replaced the floor and was wondering if any of you have had the same problem and how you fix this or do i find a new hull....thanks for your help
    Jul 2010
    Sparks Nv.
    Default Cracks
    Quote Originally Posted by no more prop View Post
    If you could post pictures probably could get more answers and info Wild Bill
    Senior Member Untamed 777's Avatar
    Sep 2010
    Central Oregon
    Default Sanger Jets
    Sanger jets with partial box stringers crack along one of the chimes. The only right way to fix this is cut the floor out and repair from both sides inside and out. The design was to create a box section with the bottom of the boat, foam and the plywood floor. Once the integrity of the floor is lost and water infiltrates its over.
    Team Untamed 777 T/E
    West Mich
    Quote Originally Posted by Untamed 777 View Post
    The bottom line is ..............................if the crack is not addressed ( repaired ) water will wick into the crack creating a bigger problem or should i say more Delamination .
    Jun 2013
    thanks for all your advise, ive tried to take pics to show you but it doesnt come up on my phone or good camera... you cant get a finger nail in the crack at all it looks like a long stress crack in the gel coat...
    RPB
    RPB is offline
    Senior Member RPB's Avatar
    Jan 2013
    use a marker or what ever to highlight
    51% of Democrats dont know the earth revolves around the sun and 49% think that Astrology is scientific. (National Science Foundation and National Opinion Research Center (NORC) at the University of Chicago 2014).
    CF BLACK
    : Carbon Fiber Fabrics and Derivatives at the Best Prices
