panther pump housing repair advice and materials
Results 1 to 3 of 3
    Senior Member Keithwidney's Avatar
    Apr 2013
    Default panther pump housing repair advice and materials
    I am fixing the pump housing box on my jet boat .it had a 3 point engine mount that lost the rubber and cracked the glass.the original owners tried doing a half ass repair .i removed the pump and ground out all the old repair and resin they just poured ecerywhere.im going to thin out the surrounding areas where i will be laying the new glass to build up a good tough area. Any advice on prep work and what materials I should use would be great. I will be using sher fab foe my supplys.
ID:	459970   Click image for larger version.
ID:	459978   Click image for larger version.
ID:	459986   Click image for larger version.
ID:	459994   Click image for larger version.
    Senior Member lilrick's Avatar
    Lakewood
    Dump the panther and go Berkeley. I did that conversion on my first jet boat and gained 12 MPH.
    My Peace
    Quote Originally Posted by lilrick View Post
    That jives with everything I've ever heard. You have it torn apart enough at this point that a conversion would not be that much of a step. You could pick up a used pump for not that much money.
    Help expand the wiki of hot boats! www.hotboatdatabase.com
