replacing my fiberglass tanks-need advice.
Results 1 to 2 of 2
    64kfordan
    Aug 2011
    Default replacing my fiberglass tanks-need advice.
    I am replacing my fiberglass tanks in my64 kinsvater. the old tanks are delaminating. I already got two nice aluminum tanks and have removed one of the two glass tanks. what would be the best way to secure it to the haul without making hole in the bottom.
    Senior Member flatwater's Avatar
    Apr 2012
    Cambridge Ontario Canada
    This is what I am trying to do to mine. I will install SS bolts into the hardwood pieces then put some resin on the back side of the blocks, attach them to the tank, and set into place to ensure proper alignment of all pieces. Once they dry I will remove the tank and fully glass the pieces into place.
    that's the plan anyway
Name:	tank mounts.jpg
