[Question] Gelcoat fading at exaust tip
Results 1 to 1 of 1
    Oct 2013
    Default Gelcoat fading at exaust tip
ID:	471505Click image for larger version.
ID:	471513Click image for larger version.
    Hey guys, just had a question for some of you more experienced people. I have a new boat that only has a few hours on it and whenever I put it in the water I get this blushing effect under the water line between the exhaust tips. Everywhere else on the boat loss good. I had it repaired with a lite sanding and buffing, then I put it in the water and it happened again. Any suggestions on why this is happening, and solutions to help prevent it in the future? Any input would be appreciated. Thanks
    Sent from my SAMSUNG-SM-N900A using Tapatalk
