need a little help fiberglass repair
Results 1 to 5 of 5
    AKA JET BOAT DAVE NOT A JET's Avatar
    mount island NC
    Default need a little help fiberglass repair
    well got a little crack is this a hard fix had a little leak though i wood reseal the pump cover took it off and when i was getting all the crap off the hull in the fiberglass below the pump cover and right above the ride plate i found it thanks mike
ID:	508562   Click image for larger version.
ID:	508570   Click image for larger version.
ID:	508578   Click image for larger version.
    DAVES NOT HEAR MAN
    Senior Member flatwater's Avatar
    Apr 2012
    Cambridge Ontario Canada
    Quote Originally Posted by NOT A JET View Post
    Not sure if it's just me, but I don't under stand a bit of what your tying to say here...
    Looks to me like your going to have to remove all hardware around the crack, grind it all down & around, and depending on how much support is required in that location, replacement of the wood maybe your best option (if it is wood), and get some fresh glass on it. I have no idea about jets (sorry), just trying to help out.
    Dec 2014
    I think you should replace wood as in future the leakage problem can be bigger .I would advice to consult the professional for leakage problems .
    Jun 2010
    Grind it out, lay in glass mat, sand it down, paint it, and go boating
    Senior Member Johnny2bad's Avatar
    Sep 2009
    Land of 10,000 lakes
    The PB Board turned me on to Sea Goin' Poxy Putty..... that shit works.
    Johnny
    Posted from my Etch A Sketch
