Painting Chrome
Results 1 to 9 of 9
Painting Chrome
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Default Painting Chrome
    Looking to paint some old chrome rims I have flat black. I was hoping to rattle can them. Any recommendations on surface prep or brand of paint? Thanks
    SoCal
    I painted my chime headers with vht primer and paint. Looked great until I ran the engine. Paint and primer peeled off in large chunks. What a mess!
    Ended up roughing up the chrome with Emory cloth, re painted and it's been 5yrs now. No problems.
    2halletts@gmail.com
    BLOWN GAS FLAT TO THE RAMP
    REST IN PEACE MY FRIEND
    Senior Member jdekruyf's Avatar
    Jun 2011
    Artesia, CA
    Rough em up with some 4-600 grit, primer, then spray em. Won't stick well unless you rough it up first and primer.
    Scotch brite or Emory cloth like flat foot'n said will work too. Just gotta rub a little more with scotch brite.
    For paint, rustoleum has always worked good for me.
    Jul 2013
    OR
    Plasti dip them. Surface prep is always the most important step so don't cut corners but the benefit to plasti dip is if you don't like it or screw up you can peel it off and do over. It's what a lot of people use these days for this type of application
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    You are gonna go to hell. The chrome gods will give you the purple burn for eternity.
    Senior Member flatwater's Avatar
    Apr 2012
    Cambridge Ontario Canada
    Quote Originally Posted by Chop Shop View Post
    ....................lol
    Aug 2010
    Albuquerque NM
    In my defense. I'm leaving the outer chrome ring. Flat black in the center.
    sacramento
    i had straight clorox bleach in my sink & it ate the chrome off of the sink drain. you might be able to remove it? just a option .
    X2 on Plastidip! They have flat black. No sanding! Just wash, dry and spray. I got five 17" wheels done with 4 cans. And I wasn't being cheap. That was three or four coats. One light misted type coat first, then, after waiting whatever time it says on the can for a recoat window, respray with medium-wet coats. That spent about two years on my Jeep with vigorous washings. That stuff is very tough! No need to sand (even chrome). It's pretty dang slick and can't beat it for $20!!!
    sorry for the bad pictures... They are the only ones that I could find on my phone
