[Question] Graphite Cleanup
Results 1 to 6 of 6
Graphite Cleanup
    Senior Member phughes SS-13's Avatar
    Jun 2012
    Sarasota, Fl.
    Default Graphite Cleanup
    Got the Flatty turned over and am prepping it for paint. Previous owner had the bottom speed coated with graphite, I'd like to remove it and just go with paint. Before any sanding on the bottom, the whole thing gets a thorough wash and wipe down with wax remover. This surface prep and wax remover is basically just a thinner and starts cleaning off the graphite, that's good, however I am going through a lot of it. I'd prefer to wipe it off rather than sand it off, that way it doesn't get ground into the gel coat. Any suggestions on what's the best solvent to use? Mineral spirits, MEK, Lacquer thinner, Xylene, Toluene, etc. Also I don't want to mess up the gel coat or the fiberglass. If need be I'll just keep buying the Wax remover but it is real slow going.
Name:	Stuart 2014 080.jpg
ID:	553962   Click image for larger version.
Name:	Stuart 2014 081.jpg
ID:	553970   Click image for larger version.
Name:	Stuart 2014 082.jpg
    Surprise, AZ
    Mineral spirits.
    Sent from my VS980 4G using Tapatalk
    Surprise, AZ
    ^^^That was informative...
    Placentia, CA
    Lacquer thinner has always worked for me.
    steveo143 AKA DiMarco 21 II
    Jun 2012
    Sarasota, Fl.
    Default Worked like a Charm
    Quote Originally Posted by 67weiman View Post
    Mineral spirits.
    Thanks for the suggestion. About an hour, couple of beers and a pile of rags and this is the result. I was actually done before I had a chance to read SteveO's suggestion or any of the worthless comments. Thanks, tomorrow.... We Sand.
Name:	Bottom 2014 001.jpg
ID:	554474   Click image for larger version.
Name:	Bottom 2014 002.jpg
    Surprise, AZ
    Welcome. Looking good.
