[Question] Screw holes
Results 1 to 3 of 3
Screw holes
    Woodland
    Default Screw holes
    I'm going to take the bow rail off of my boat. What is a good way to plug the screw holes? I was thinking of drilling the holes a little larger then putting a piece of 1/4" dowel rod and covering hole with a couple of drops of resin.
    Senior Member littlejockocougar's Avatar
    pleasant hill
    Mike assuming the holes are 1/4 in since you mentioned dowels that size. Are you planning on repaint? If not, I would countersink the hole, and install a countersunk stainless bolt if you bcan get a nut on the other side..
    Senior Member flatwater's Avatar
    Apr 2012
    Cambridge Ontario Canada
    Id use the wood, or you can fill with fiberglass putty... How many holes are you talking about?
