clear coat question
Results 1 to 11 of 11
clear coat question
    Default clear coat question
    how long should it take for a 2 stage clear coat to cure????
    Senior Member jdekruyf's Avatar
    Jun 2011
    Artesia, CA
    To color sand and buff, most spec/tech sheets will say to do it within 24 hours but that's obviously if the temp doesn't drop too low and most sheets assume the clear is in a booth/oven. Some clears can take awhile to "fully cure" though but there acceptable color sand and buff time varies. Best bet is to go off tech sheet if you have one. If you don't, you can try looking it up on the company's web site.
    Sometimes it's best to wait a few days to color sand if your not that comfortable as the clear will get harder/cure more the longer you wait, which obviously creates more color sanding time. That's why most tech sheets have you do it ASAP as the clear is still a little softer and cuts down and sanding and buffing time for body shops. But if you're new to color sanding, it increases the risk of sanding through clear coat. I let my boat cure for about 3-4 days before I started wet sanding as I would rather spend a little more time sanding than risk cutting through clear.
    I'm a novice when it comes to painting but that's just what I've picked up in my research.
    Thanks for the response. problem my son had yesterday was not with sanding but more the buffing. problem was he set the compound bottle down on the boat as he was buffing and moving then noticed the bottle left an indent in the clear. clear was shot weeks ago!!!!
    Jun 2011
    Artesia, CA
    I had a little fingerprint like smudge in my scoop from handling it after the clear was sprayed but a few days later it looked a little better. After about 2 weeks you couldn't see it at all. Clears can take almost 3 months to "fully cure". I'd give it a few days and see how it looks.
    Quote Originally Posted by jdekruyf View Post
    you were correct on the flow out! He decided to put it out in the sun for awhile and all issues went away! boat will get a good wash this weekend and come back in the garage for the final buff and see how it turns out!!!! This is his first paint job and he is VERY PERTICULAR as to the final product! His tape work and prep are beyond compare. I wish I could toss pictures out but he will not allow it till he is good with it! He is a perfectionist so go figure. He has done the bottom blueprint and full pump set-back and can be seen on face-book but I am hands-tied at this point!
    Jun 2011
    Artesia, CA
    Good deal and glad it worked out for him and yeah I give major thumbs up to guys that can mask and overlay different colors and all that. One thing to spray but the prep and masking is not simple by any means. I've tried and failed and that's why my boat ended up all white!
    Post some pics when it's all done and he approves!
    New here Beer:30's Avatar
    Bakersfield, CA
    By chance - IMRON?
    By chance - IMRON?
    Not a chance!
    Bakersfield, CA
    Not a chance!
    Whew. Ok. My nephew just tried to spray his jeep with satin-green Imron. They shot some of the parts two weeks ago and I think it's JUST NOW curing! I looked up the drying time and it's SIX DAYS.
    So, they switched to Nason BC/CC (satin clear). It's all finished and almost put back together and the Imron is STILL DRYING.
    I have done a few boats and for his first I can't believe his tape work and I will take a shot and post it this sunday after the buff WHEN he is not looking! Thanks for all the input!
    Senior Member Billy-B's Avatar
    Alta Loma, Ca
    All urethane clears will vary in dry time. Things like weather temp, humidity, how mnany coats, reducer you used if any ( I cut my clear 10%). What brand did he use? Cheaper clears use different/cheaper resins then the more expensive ones. And my PPG rep said clear can take as long as 8 months to fully harden.
    N.R.K.A. CEO of the Needles River K Association.....The largest "K" boat assoc in the WORLD. 30 boats strong & growing.
    And the #1 backer of " EASON " for President.
    "Blown Gas Flats to the ramp!" - Chris Blevens
