Thru hull exhaust
Thru hull exhaust
    Junior Member Campy88's Avatar
    Aug 2014
    Default Thru hull exhaust
    So i have thru hull exhaust and the flanges that are on the outside of the hull are aluminum, if i polish it will it last or will the water dull it back up??
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    alum always needs polishing, stainless-steel a little less, chrome just needs wiped down every time you exit the water.
    New Jersey
    If you polish and then clear or color powder coat, that would hold up the best. You could polish and anodize but it won't hold up as long as powder.
    Raw polished aluminum will oxidize and dull quickly and requires frequent polish and wax to stay looking shiny.
    Doug
    Aug 2014
    Thanks i think i'll just powder coat them and be done
