Need help fixing indents on stringers from past stringer washers.
Results 1 to 1 of 1
    Sep 2012
    Default Need help fixing indents on stringers from past stringer washers.
    I plugged all the old holes in the singers because of all new hardware installed, but where the old holes were the stringer washers have left indents in the wood. Short of layering up resin, is there anything else I can use? I'm going to paint the stringers black, so I'm not worried about using fillers. Wasn't sure if I could use duraglass, or something close?
