Gel coat not dring
Results 1 to 2 of 2
Gel coat not dring
    Dec 2012
    Default Gel coat not drying
    I mixed and spryed some gel 50/50 with duratec used 3.5 tenths of a oz of hardner to 1 qt of matrial still dose not dust up when trying to dry sand its dry enough it dose not gum up the paper it water sands good Any help
    Diamond Bar, Big River
    Probably best to contact Duratec tech. dept. directly, they are very helpful. They are owned by Hawkeye Industries Inc. located in Bloomington Ca. Here's their contact info.
    email: assist@duratec1.com
    ph. 1/800/281-4975
    Did you add any acetone to the mixture? If you did, that will effect (slow) the catalyst requirement for mixture ratio. Maybe spray the area with pva and let it sit for a couple days. If you can warm the gel coated area with the sun or other means it may help as well to get the material to completely cure out. Good luck.
