[Question] what is the correct way to lay marine plywood down on a shovel nose hydro
Results 1 to 5 of 5
    Jun 2010
    Default what is the correct way to lay marine plywood down on a shovel nose hydro
    I was told that you glue down the outside edges only of the plywood I'm looking for a second opinion from someone who may have a different idea or another way remember his is a shovel nose hydro that I have
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Oh I cant wait to hear Ray's (1bdhondo) reply to this one!!!!
    Senior Member PRO53's Avatar
    TOMBALL, TEXAS
    I have a shovel nose to redo myself, any pointers on stringers and plywood?
    OMEGA JET, AND Sanger Shovelnose Hydro
    "DOWN WITH THE SICKNESS"
    AND A LIST OF ONGOING
    Jun 2010
    Quote Originally Posted by PRO53 View Post
    Do not follow the aboves advice unless you want to drive and have the floor and stringers come loose and probably break your boat into pieces
    Diamond Bar, Big River
    Default coring
    check out screamandfly.com They have a rather active section on fiberglass repairs. A lot of good technical discussions on coring there.
