Clear anodizing removal
Page 1 of 2 12 LastLast
Results 1 to 14 of 17
    private dancer convincor's Avatar
    at the lake
    Default Clear anodizing removal
    Does anyone know how to remove clear anodizing that has experience doing it. The only way I can get it off is sanding. Looking for a chemical way to remove or something easier than sanding.
    It's hard work being a trophy husband
    Sep 2008
    Easy off oven cleaner.
    Senior Member OLD MAN ON THE LAKE's Avatar
    Phoenix
    Dep concentrate degreaser. Home Depot
    Depending on the temp. should take 10 to 20 minutes.
    Do NOT get on your skin or clothes.
    Placentia, CA
    Dep Industrial Purple @ Home Depot.
    steveo143 AKA DiMarco 21 II
    Quote Originally Posted by convincor View Post
    If you plan to get it anodized again,, the anodizing ship should be able to strip it for you, little to no charge.
    Jun 2014
    Alan @ jenco always strips the stuff for me , I have done a few small parts but with Jenco so close its just easy to run it by
    Quote Originally Posted by ERV JR View Post
    Right, didn't know where the OP was located, but even when I was a kid Jenco was the place!
    Jun 2014
    I don't know his location either, but I have tried the Ez off, several coats and then sanding and its a pain. Hell I have gone to Jenco since I was a kid. Maybe the Zep degreaser would be worth tying, little parts and fitting would be nice to do at the shop
    Sep 2011
    Colton, CA
    Sep 2011
    Colton, CA
    Test that Dep purple cleaner on a junk part first to make sure that the results you get are the results you expect.
    Good luck,
    Joe
    Jun 2014
    Quote Originally Posted by Flusher View Post
    Good luck,
    Joe
    what dose that mean? poor quality ? I expect stripped to be stripped, ready to belt and polish. I dont want to buy the crap if it dosent work. Hell I work in Colton, how about I swing by and you show me some parts you have done ?
    West Mich
    Just a thought , and a very cheap one at that why not try fingernail polish remover that has Acetone in it or just try Acetone .
    at the lake
    Thanks for the replies. I am in Ohio. I would consider shipping them to someone if it was a reputable company. The parts I have are swim steps.
    Senior Member Trigger's Avatar
    Aug 2011
    Lewisville, TX
    Get ahold of your closest friend that is in the heat and air business and have him bring you some A-coil cleaner. It's an acid I believe and all I have seen is kinda pink in color. It'll strip it in minutes with zero labor and will be ready to polish or whatever as soon as you are ready with the rag and polish.
