Crack in bottom of hull
Results 1 to 2 of 2
    Emmett, Idaho
    Default Crack in bottom of hull
    So I was under my cole v-drive, pulling the prop, and noticed a 3-4" crack running from the prop shaft through hull hole, back towards the strut. The hull is a bout 3/4 - 7/8" thick. How dose one fix this? Sorry no pics
    West Mich
    Actually pic's would be helpful , and given the area of concern ( location ) if I was you I would address this problem very soon because it (the crack ) can, and will only get worse over a period of time................. with water wicking into the crack causing more damage to the hull or delamination, and in my opinion the best fix would be to grind & re-glass the area of concern .
