Instead of speedcoat for the bottom of a flat
Results 1 to 9 of 9
    Jun 2011
    Default Instead of speedcoat for the bottom of a flat
    What is the best thing to do to the bottom paint/clear, instead of using speed coat?
    West Mich
    Quote Originally Posted by purpledragon View Post
    First off could you be more specific and what I mean by that is ....................................are you trying to get a surface that compare's to Speed coat or just a painted surface because in my opinion Speed coat is a waste of money considering wet sanding the bottom of the hull or running surface can and will give you as much or more ( speed ) for less money then Speed coat
    Jun 2011
    Just wondering if there is a way to sand the clear on the running surface to rough it up and make it work.......
    Senior Member ClassicBoats's Avatar
    San Bernardino, Ca
    Speed coat or bottom prepping should be a last trick in the bag, have you straight edged the bottom to see if you would even benefit?
    Jun 2011
    Many thanks Artie.........many thanks.........
    West Mich
    It was my pleasure , and you are Welcome . Artie
    Diamond Bar, Big River
    What grit would you recommend for that OG? Do you sand in a certain pattern or just parallel to the running surface?
    Jun 2011
    OG, I told him what you said and advised.........hope you don't mind..........PD
    West Mich
    It is all good Ken and to tell you the truth I have been gone and refused to get caught up with vacation time using a PC....... if you know what I mean.................... JET JUNKY , I apologize for not getting back with you sooner, and to tell you the truth i have done power boats in #800 #1000 #1200 depending on the boat & customer with a few Sail boats thrown in for good measure ( race ) done in # 1500 always using a Jitter Bug sometimes hand sanding if need be for those hard to get at places .
