Stringer replacement
Results 1 to 3 of 3
    Hostile88
    Apr 2011
    Ogden utah
    Default Stringer replacement
    I'm putting full length stringers in my southwind. What's the best way to shape and fit them?
    Aug 2009
    Quote Originally Posted by Hostile 88 View Post
    try screamandfly.com. They have a nice forum on fiberglass repairs
    West Mich
    First ...................you must remove the stringers and prep everything out / surface . Two , you need to figure out the degree of dead rise / angle you have on the bottom of the hull using an angle finder , T-Bevel or ................. and when it come's to cutting and shaping the stringer itself I will use a Table saw for a straight cut and or a jig saw for a rounded cut or irregular shape of a Stringer although ( note ) if no table saw is available a jig saw will fit the bill for just about everything , and when it comes to shaping the stringer or rounding the top ( leaving no edge ) so your fabric has something to roll over or onto I always use a router going with a 1/4 , 1/2 , or 3/4 - round bit depending on the thickness , and if no router is available going with a machine sander , da , electric , file board , or even hand sanding just to knock or round off the edge ( on top of the stringer ) so your fabric will have something to roll over on minus a sharp edge .
