Need Fiberglass / Gel Shop Recommendations or Feedback
Results 1 to 2 of 2
    Default Need Fiberglass / Gel Shop Recommendations or Feedback
    Posted in the jet section too...
    I'm looking for a top notch fiberglass/gel shop. I'd like top quality work at a reasonable price from a place that really knows their stuff.
    Someone mentioned Pat's Fiberglass. Any experiences there or other recommendations? Nobody local to me seems to fit the bill, so I'm planning on a road trip to wherever the work is done and I won't be able to stop by and check in while the boat is there.
    The boat is a mid '80's hand laid Eliminator 18SS splash. Here's what I'd like to have done:
    • Full length stringers replaced and finished with the intent to leave them exposed
    • Thru transom exhaust holes filled
    • Fuel fill holes filled
    • Various small holes from ski racks, running lights, etc filled
    • Capped (hull to deck joint is butt construction)
    • Interior edges smoothed
    • Fix some crazing in the gel around the fuel fill holes and bulkheads
    • Gel bilge and inside of transom
    • Bottom has been blueprinted with Jack at MPD overseeing the work, but it's been quite a few years and I'd like to have it checked and touched up as needed
    • Gel is in excellent condition overall, but I'd want all the new work to blend flawlessly and the boat to be in like new condition.
    I realize this isn't going to be cheap, but with the cost of a brand new bare hull around $8500 bucks I'd like to be a ways under that. I'd appreciate any suggestions or feedback. Feel free to PM me.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Try Smooth As Glass in Patterson CA
