Removing graphics
Results 1 to 5 of 5
Removing graphics
    Jul 2015
    Default Removing graphics
    Have some painted graphic stripes on a factory boat want to remove and just buff the gel coat,have buffed thru them so I KNOW THERE IS NO PRIMER UNDER THEM.Click image for larger version.
Name:	freeport 375 - port front.jpg
ID:	802874don't really want to sand them off.Thanks JOHN SR
    Sep 2014
    Razor blade
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    No razors they can chip the gel.... just wet sand thru the paint until its all gone, it wont hurt the gel, then buff it all out.
    Member gary5224's Avatar
    Feb 2013
    Atlanta
    Paint stripper a plastic squeegee and a water hose and pay attention to what you're doing
    West Mich
    Depending on how you do this most likely you will have to block out the area of concern wider then the graphic itself to make everything look the same or even / flush to the hull side's .
