fiberglass repair
Results 1 to 5 of 5
fiberglass repair
    Default fiberglass repair
    I have a 1973 dimarco 19' deep vee hull it is turned upside down now to repair very slight gel-coat blistering and to change the color. I am thinking about painting the whole boat rather than gel-coat and wanted to get input on both. Also wanted to know how to tell if this boat is polyester or epoxy layup. I am thinking it is polyester but that is only a guess Thanks for any help!
    West Mich
    Quote Originally Posted by sanger buzz View Post
    To tell you the truth unless you are planning on using Epoxy for your repairs i would not worry about what resin was used ........but on the other hand i can almost bet that Poly or Vinyl was used in your build , and not to mention that if you paint the hull you will save your self a whole lot of X-tra work opposed to Gel .
    Placentia, CA
    All Westcoast builders were using Polyvinly resins at the time.
    steveo143 AKA DiMarco 21 II
    The bottom side of the hull looks good but will need the fiberglass repaired around the bow eye-bolt and 4" ahead of the rudder. And around the rudder . The eye-bolt had worked loose and elongated the holes in the fiberglass , at the rear it looks like the prop might have broke or came off and hit the hull. Both should be easy to fix they are about 1/4" deep . I was not sure which resin to use I thought polyester would be fine but not sure? By the end of this weekend I should have half the gel-coat removed from the bottom . the raw fiberglass looks real nice after block sanding . Thanks for the reply's and any input. Sangerbuzz
    Diamond Bar, Big River
