Help SWTD
Results 1 to 1 of 1
Help SWTD
    Hostile88
    Apr 2011
    Ogden utah
    Default Help SWTD
    I picked up a 1980 SWTD. Found some problems with it. I've got some cracking and bad repair work to fix. Under the stringers the boat has what I guess you'd call a plywood core that runs clear past the bulkhead. My question is can I cut a section out of the plywood and do my repair then section it back in? Or do I need to pull all the plywood. Thanks in advance.
ID:	875785   Click image for larger version.
ID:	875793   Click image for larger version.
