Making a solid into Metalic.......Is it possible?
Results 1 to 3 of 3
    Senior Member spectralen's Avatar
    Aug 2009
    Mi.
    Default Making a solid into Metalic.......Is it possible?
    If I have a car with your basic solid color with clear coat, is it possible to scuff the clear, spray some metal flake, then spray some more clear, and then have a metalic color? I guess what I'm asking is can I change from solid to metalic? If I could do something like this I could leave the door jams, engine compartment and trunk as is.
    Senior Member Johnny2bad's Avatar
    Sep 2009
    Land of 10,000 lakes
    Your car will end up looking like a sugar cookie....you want snow globe.
    Johnny
    Posted from my Etch A Sketch
    Senior Member inthecurl's Avatar
    Feb 2009
    So.Or
    This is possible, but would be a flake job, not a metallic. Sand clear coat down with 1200 grit (to avoid seeing scratches in clear when you re clear) , mix flake with a intercoat clear, spray as many coats as you would like, then re clear.
    This is not a metallic thou!!!! It will look much "heavier" than a metallic. Think low rider..
    Obama Presidency: "If it's not broken, fix it til it is!!!!"
