Stringer replacement
Results 1 to 2 of 2
    Jun 2016
    Default Stringer replacement
    I've spent a considerable amount of time reading through the threads about stringer replacement and have found a ton of info, so thank you to those who posted about your experience. I am going to start my own stringer replacement project and need some help. After reading, I will be ordering 17 oz biaxial glass with no backing and using epoxy resin. My question is how far do I overlap each layer? I'm going to layer usin the opposite of the west system, smallest layer first and so on. How many layers are recommended? How much resin would a novice glasser need to do a full stringer boat with 16' stringer? (Assuming I'm gonna screw up and waste some.) Do I need a different type of fabric in between layers or a different type for a finish layer? Is it best to do 1 stringer at a time or cut them both out? I should include they are being pulled for delamination not rot. I apologize for the format of the post and any typos, I'm fat fingering this from my phone. Thanks in advance Steve
    West Mich
    Quote Originally Posted by sjackson007 View Post
    So before i go into this you are you going to be going with mutable layers of fabric using 17 oz- 1700 Bi Ax staggering each layer of fabric Small , Large , Larger , and not to mention that i am somewhat ole school believing that the more beef the better ( fabric ) which to some just might be overkill considering three layers of fabric for stringers was of the norm at a few Co's ( Skater ) that i worked for in the past with two layers most likely being sufficient for your project but that is your call .
