Scratches/Gouges in bottom of hull
Results 1 to 2 of 2
    Senior Member Bonzen's Avatar
    Apr 2012
    Default Scratches/Gouges in bottom of hull
    I have some decent ones...all the way through the white outer layer. Mostly from dragging on rocks that I didn't see. Whats the best DIY way to fix these?
    Saw this stuff at Walmart, any good?
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    New Jersey
    This filler probably is not the best choice. It has short fiberglass strands in it to reinforce the filler, which makes is hard to work and spread in gel-coat deep scratches.
    ( 3M Marine High Strength Repair Filler 1 Pint 46012 3M Solutions for boat owners, marinas, boat builders and industrial ship builders )
    If you decide to use filler for gel-coat depth scratches, look for one without the fibers. In addition, look for a filler that does not use "TALC" as a thickener, since TALC absorbs water.
    Probably the best choice would be a gel-coat paste. I believe you can buy the gel-coat paste in marine stores and online.
    I am not an expert, but that is my take.
    Doug
